Date/Time: Tue, 11 Feb 2025 09:01:28 +0000
Change Study Input Value from Spreadsheet
View Count: 545
[2020-08-28 14:11:23] |
osaga - Posts: 53 |
Hello SC I want to be able to change a Study Input Value from a spreadsheet cell. Is it possible to reference a spreadsheet cell value from a Study Input Value? And can it be done from a simple blank spreadsheet with nothing else on it? Thanks as always! |
[2020-09-02 10:59:19] |
Not directly. You would have to create an ACSIL study to take the value from the spreadsheet cell and then update the study with it. Refer to the information here for getting started with ACSIL: Advanced Custom Study Interface and Language (ACSIL) ACSIL can access Spreadsheet cells and can modify study Inputs. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2020-09-02 10:59:36
