Date/Time: Tue, 11 Feb 2025 01:37:02 +0000
Draw vertical lines indicator
View Count: 1204
[2020-08-28 09:40:23]
User962067 - Posts: 11
Good morning, is there any indicator that allows you to draw vertical lines every 5 minutes or the desired time and at a specific time interval? for example: draw vertical lines every 5 minutes between the hours of 9:30 and 12:00
[2020-08-28 09:57:03]
Ackin - Posts: 1865
Probably not periodically
One line at a specific time:
Time Line
Time Line
or
Grid lines every time interval:
Chart Menu: Vertical Grid (Chart menu)
[2020-08-28 10:00:25]
Ackin - Posts: 1865
and you can also transfer from 5 minute timeframe via "Study / price overlay" close Bar and show it filtered with study Color bar based on alert as you need
[2020-08-28 10:56:31]
There is the Vertical Grid:
However, it will draw vertical lines across the entire chart. You can adjust the Session Times:
Chart Session Times
