Date/Time: Tue, 11 Feb 2025 01:43:11 +0000
Symbol change
View Count: 846
[2020-08-27 23:38:52] |
User161549 - Posts: 81 |
Hello I was trying to look at the russell 2000 on a TPO profile normally I just look at the E-mini and I changed the symbol one of my TPO profile charts from /ES to /RTY and it changed all the charts I have in my chartbook to that symbol, How do i change just one chart to the symbol without changing all the others ? |
[2020-08-28 10:59:26] |
It sounds like you are using Chart Linking. You will need to disable that. Refer to: Working With Charts: Chart Linking Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
