Date/Time: Tue, 11 Feb 2025 01:43:05 +0000
Session time Issue
View Count: 615
[2020-08-27 19:10:35] |
Sudhirc - Posts: 54 |
In Chart Setting: Under Session Times (HH:MM:SS) I've Start Time: 16:30:00 & End Time: 9:29:59 and did not select the evening Session. When i click OK button it is automatically setting the default sessions i.e 9:30 to 16:59:00 & Use Evening Session as 17:00:00 to 9:29:59 How can i get a chart with only the evening session or the set times? http://www.sierrachart.com/image.php?Image=1598555413100.png |
[2020-08-27 22:39:10] |
If the chart Session Times are unexpectedly changing, refer to: Chart Session Times: Session Times Automatically Changing Unexpectedly Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
