Date/Time: Tue, 11 Feb 2025 01:58:45 +0000
Volume bars by specified criteria
View Count: 483
[2020-08-27 13:42:52] |
Ben A - Posts: 123 |
Hi there, Is there any way to create volume candle bars coloured by both diagonal positive delta sum and diagonal negative delta sum. I currently have this setup to show with Fill rectangle to Zero, however is there any way of showing this in one candlestick resting on the zero line like a normal volume bar but with two colourings for these inputs or those of my chosing? Thank you, |
[2020-08-27 18:24:42] |
No this is not supported.
