Date/Time: Tue, 11 Feb 2025 02:01:51 +0000
number bars calculated values - problem with cumulative delta numbers
View Count: 762
[2020-08-27 12:58:51]
User641030 - Posts: 13
I run two instances of Sierra chart. The Day Cumulative AskV - BidV values of ES futures are different in the instances. The most recent value is 8082 in one instance and in the other it is 8243. The chart settings (like session times) are identical in both instances. I'm looking at only the day session and not the evening session. I'm worried about the integrity of these numbers. Please let me know how to fix it.
Hari
imageNumberBarCalculatedValues1.png / V - Attached On 2020-08-27 12:57:12 UTC - Size: 30.44 KB - 222 views
[2020-08-27 13:01:25]
Second image -
imageNumberBarCalculatedValues2.PNG / V - Attached On 2020-08-27 12:59:14 UTC - Size: 8.72 KB - 224 views
[2020-08-27 18:26:18]
Go through all of the items here to determine what the issue is:
Chart Studies: Resolving Study Differences (Resolving Study Differences)
Also consider using the Denali Exchange Data Feed if you have any market data issues or inconsistencies:
Date Time Of Last Edit: 2020-08-27 18:26:54
