Date/Time: Mon, 25 Nov 2024 12:15:10 +0000
Limit days downloaded on SC real time data feed
View Count: 1118
[2014-02-04 00:21:45] |
WarriorTrader - Posts: 245 |
Hello, How do I limit the amount of days that are downloaded? I only need 20 days of data. I am using OEC with the SC real time data feed. I tried the settings for OEC but that has no effect. Using version 1070. Thx, WT |
[2014-02-04 01:22:27] |
You cannot because this is automatically managed now. The full amount of data is downloaded.
[2014-02-11 17:39:58] |
Hello, Would be nice if you had a “Delete data from current Position to beginning” (instead of to end) button somewhere on the “ Intraday Data Editor“ but then again that may just confuse people. Maybe you could make it small and out of the way since most people will not use it? Or maybe you could label it "reduce file size." Thx, WT |
[2014-02-11 18:24:22] |
We do plan this kind of feature in the Intraday Data Editor.
[2014-02-11 18:29:52] |
Great. You could also give the user the ability to split a file at a desired location - similar to what you do in the "Large Data File Settings" in the "Data/Trade Service Settings" Thx, WT |
