Date/Time: Tue, 11 Feb 2025 01:53:55 +0000
2nd and 3rd Instance Not Reloading Properly
View Count: 638
[2020-08-26 23:27:21] |
User128888 - Posts: 30 |
Hi, I have set Instances To Run on Startup to 3. Upon start up, the 2nd instance will not launch. The 3rd instance will launch. And the 3rd instance doesn't quite reload with the same window size that I had it. This issue came up after I tried to load a 3rd instance. Before my 1st and 2nd instance was working fine. When I try to load a 3rd instance, this started happening. What should I do? Date Time Of Last Edit: 2020-08-26 23:32:26
[2020-08-27 06:41:12] |
Refer to that setting here to know exactly how to use it: General Settings Window: Instances to Run on Startup (Global Settings >> General Settings >> General >> New Instances) And the 3rd instance doesn't quite reload with the same window size that I had it. Refer to:Window Size and Position Not Restored When Opening Chartbook Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2020-08-27 21:36:04] |
Those instructions were helpful. Regarding the window position, I found a way to do get it to remember the position/size on my 3 monitor setup. Windows 10 was not remembering the position/size if I drag the window to the right edge of my monitor to have the window automatically fill up the right half of a monitor. If I just manually move and manually adjust the position and size, windows 10 will remember my size and position. |
[2020-08-27 22:21:11] |
Regarding post #3, we will add that to the documentation.
