Date/Time: Thu, 19 Sep 2024 01:05:59 +0000
IB Chart Trading Problem
View Count: 1275
[2014-02-03 21:45:23] |
User35209 - Posts: 1 |
Hi I am able to log into IB also trade in Sim mode. When I go to live mode using chart trader My orders apper on the chart but do not transmit through IB. The order you can see is waiting there to transmit at IB, but has not gone through. When I try to press transmit in the IB window it will not go through. Also the I am not able to remove the order from the chart window by clicking on the x. Like I said it works fine in sim mode. Any ideas? Thanks Nigel |
[2014-02-03 22:33:43] |
It sounds like the Orders remain with an Order Sent Status. To remove the orders from the chart, select Trade >>Refresh Trade Data From Service. This command might not remove the orders if it is done soon after you submit the orders. Please contact Interactive Brokers and see why is that API orders are not being accepted by Trader Workstation. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2014-02-04 08:38:26
[2014-02-04 08:37:49] |
User40117 - Posts: 56 |
hi, i'm considering IB as a broker. When reading this i'm a bit confused, do you still need to use IB's TWS if you place orders within SC ?
[2014-02-04 08:39:30] |
Yes, Sierra Chart needs to connect to Trader Workstation to submit Orders and receive all of the order related data and market data. They do have a lightweight version they call something like TWS or IB Gateway. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2014-02-04 08:49:00] |
ty, Is it possible to use IB Gateway instead of IB TWS? So the IB gateway is just a background app that connects your SC with IB account. Is this the case with all brokers, or do some brokers offer straight connection with SC ? |
[2014-02-04 08:53:07] |
All other trading services that Sierra Chart works with connect direct to the trading service. Although in the case of TransAct and Rithmic there are bridge programs that are used.
