Date/Time: Wed, 12 Feb 2025 18:55:03 +0000
min() max() question
View Count: 836
[2020-08-26 15:11:54] |
mkata - Posts: 103 |
I updated to the latest version and when re-compiling my studies I get this error for min() and max() functions. It will compile if I replace max() with std::max() but this seems off. Can you comment on this? Thanks. error: 'max' was not declared in this scope; did you mean 'std::max'? | ^~~ | std::max In file included from /usr/lib/gcc/x86_64-w64-mingw32/9.3-win32/include/c++/algorithm:62, from scstructures.h:24, from sierrachart.h:22, /usr/lib/gcc/x86_64-w64-mingw32/9.3-win32/include/c++/bits/stl_algo.h:3462:5: note: 'std::max' declared here 3462 | max(initializer_list<_Tp> __l, _Compare __comp) | ^~~ |
[2020-08-26 17:18:13] |
Use std::max().
[2020-11-13 01:53:40] |
This is just a note to myself: The reason why this happened is because I had the "math.h" header file before "sierrachart.h". If you put math.h after "sierrachart.h" then it will use max() and not std::max. But it turns out I didn't need math.h at all because it is already included in "sierrachart.h". |
