Date/Time: Mon, 10 Feb 2025 15:25:03 +0000
[User Discussion] - Trade Sequence
View Count: 594
[2020-08-26 14:37:55]
User520896 - Posts: 1
I was wondering if there is a way to create and order that will reverse itself at the stop point and also double the order position. So as an example. A long entry (1 contract) with a 20 tick stop and 20 tick target. If it goes to the stop -20 ticks it will close out the 1 contract and go short x2 contracts and then again if it hits the stop again it will reverse and go long x4 contracts, so on and so on. Until it reaches 32 contracts. I’m not sure if there is a way to do this or if it would be something I would need to have coded. Thank you so much.
[2020-08-26 17:23:17]
Sawtooth - Posts: 4173
You would need to have it coded.
It would best be done with ACSIL, but it might be possible with the Spreadsheet System for Trading study.
