Date/Time: Sun, 13 Sep 2026 09:59:40 +0000
How to highlight the price in the DOM
View Count: 3651
| [2020-08-26 12:49:48] |
| User925659 - Posts: 39 |
How do I turn on the setting to highlight the current price on the dom? As of now I just have the separation line.
| [2020-08-26 14:19:31] |
| John - SC Support - Posts: 47854 |
It sounds like the following setting has been disabled (the Enabled button is not selected) or perhaps the color is set to the same as the chart background: Graphics Settings: Last Trade Price Box Also refer to the 2 items below that one for the Foreground and Highlight options for the same item. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
| [2020-08-26 14:34:37] |
Right. I tried that and enabled the box. I got nada. So I opened a regular trading dom V.S a chart trading dom and went through each option. I am able to do it in the regular trader dom, but the same option is not available on the chart dom. With the option that you suggested, I turned the color to white (my dom back ground is grey) and checked the enable box. I also made sure I had global settings turned off. The box for "Last trade Price Box Outline" is enabled, and the "Last trade price box foreground" is greyed out. I have also tripled checked that I have "Last Trade Price Box" Color- White and enabled. I am using a Chart Dom, because I can clear recent bid and recent volume with the profile. I don't think I can do that on just a regular trading dom? |
| [2020-08-26 14:57:52] |
It sounds like you are doing the right things, although we are not sure what you mean by "the same option is not available on the chart dom." Can you please give us a few screenshots so we can see what you are referring to. As to clearing the Recent Bid and Ask data, you can do that for the Trading DOM. Although there is not a specific menu option on the Trade DOM, selecting the option on the main Sierra Chart menu for a chart that has the same symbol as the Trading DOM will reset the values. Refer to the information here: Trade Menu: Clear Recent Bid/Ask Volume (Trade menu) For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
| [2020-08-27 06:50:58] |
Update Sierra Chart to the current version following these instructions: Software Download: Fast Update There has been updates to those color settings. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2020-08-27 06:52:56
