Date/Time: Fri, 18 Sep 2026 17:18:51 +0000
[Programming Help] - C++ std::string to SCString
View Count: 2559
[2020-08-26 11:25:44]
User253985 - Posts: 24
How do i get characters from a std::string into a SCString.
example
const char* SheetCollectionName = "TesterWesterSpreadsheet";
  const char* SheetName = "Sheet1";
  void* SheetHandle = sc.GetSpreadsheetSheetHandleByName(SheetCollectionName, SheetName, false);
  std::ifstream longs (testerwester.csv");
  SCString messagee = "File Open Error";
  if(!longs.is_open())sc.AddMessageToLog(messagee, 0);
  std::string date; // cant change these string's to SCString's because loop won't work
  std::string time;
  std::string value;
  std::string vvalue;
  for(int i = 1; i < 6; i++){
    std::getline(longs,date,',');
    std::getline(longs,time,',');
    std::getline(longs,value,',');
    std::getline(longs,vvalue,'\n');
    SCString date = date; // This doesn't work, i need to know how to make it a SCString
    SCString time = time; //
    SCString last = value;
    SCString volume = vvalue;
    // populates built in spreadsheet
    sc.SetSheetCellAsString(SheetHandle, 0, i, date); // I think the string has to be a SCString?
    sc.SetSheetCellAsString(SheetHandle, 1, i, time);
    sc.SetSheetCellAsString(SheetHandle, 2, i, value);
    sc.SetSheetCellAsString(SheetHandle, 3, i, vvalue);
    longs.close();
Output is blanks, the getline loop works,
cheers :-)
[2020-08-26 12:06:11]
User907968 - Posts: 883
You could use string::c_str function - https://www.cplusplus.com/reference/string/string/c_str/
Also, give the SCString objects different names to the std::string objects.
SCString sDate = date.c_str();
or
SCString sDate(date.c_str());
[2020-08-26 12:15:14]
Thank you so much, your response helped me a lot, much appreciated.
