Date/Time: Sun, 07 Jun 2026 07:26:15 +0000
Compact Values Toolbox
View Count: 893
[2020-08-25 21:35:21]
User845052 - Posts: 75
1) This box, on occasion, will disappear from my window and I won't be able to pull it back up by re-setting it. I checked the workspace, but it's not there. I'm not sure where it ran off to. I'm sure it will pop up again after some settings adjustments/restarts, but ideally if there was a way to dock it in location, would be best.
2) Additionally, it would be nice if you could provide a highlight selection feature between two almost overlapping lines. When you have two lines drawn fairly close to one another, but not even touching, the software will (appear to) only let you select one of the lines in the converging area. SO say if I have to cut several lines at the point of the last candlestick bar (so they do not distort), often there is one line that I will not be even able to select for modification because the software diverts to a nearby (not necessarily touching) line. In this particular situation I could not simply select the line from an unobstructed area, because the point is that I select it at that specific spot so that the drawing may be "Cut" accordingly. If there was a tool or something that allowed scrolling through highlights within a particular close proximity, would be helpful.
[2020-08-26 00:08:07]
1. When the Compact Tool Values Window is not displaying, and you have the option selected in the Window menu, then refer to the following:
Chart Drawing Tools: Cannot See Values Windows?
2. When there are converging drawings and you are trying to select one in that region, you should be getting a number displayed on the drawings that allows you to select the specific one you want. Refer to the information here (this is in the Move Drawing section, but applies to any option where you are trying to select one of many drawings):
Chart Drawing Tools: Converging Drawings
Also refer to:
Chart Drawing Tools: Manage Chart Drawings
