Date/Time: Sun, 04 Oct 2026 01:03:19 +0000
Anyone In BC Canada know of a Futures Broker that supports TT for clearing?
View Count: 883
| [2020-08-25 19:10:06] |
| enemyspy - Posts: 307 |
This is directed at anyone Support Staff users whoever. I really dislike Interactive brokers. I have been searching far and wide for a U.S broker accepting B.C residents with a clearing firm that supports TT so that I can try sierra chart order routing. So far I have found 2 for B.C but unforunately they both have use iron beam clearing for B.C which can only support CQG. Anybody got any suggestions? Thanks |
| [2020-08-26 00:30:25] |
It is fine to use CQG if that is the only choice you have.
| [2020-08-26 00:40:37] |
Alight. If you ever plan to come up with a routing solution to work with iron beam clearing and end up completing it. Please put it in the alert box that comes up saying your services balance is too low (if not too much trouble). Also in your opinion is CQG at least less problematic than TWS? |
| [2020-08-26 22:07:05] |
It is fine to use CQG and that is what we recommend in your case. Definitely much much better than TWS. We are still the process of working on our own direct CME order routing which could be used by Iron beam. But we really do not think that is going to be available until next year for retail use. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
