Date/Time: Mon, 10 Feb 2025 16:24:34 +0000
Second Data Feed
View Count: 463
[2020-08-25 16:46:32] |
User353062 - Posts: 32 |
OK, I'm using SC Futures Order Routing/Data [trading] setting. I have one chartbook running on NQ. How can I have second chartbook to run on EUREX using second connection?
[2020-08-26 00:18:14] |
Just create a new Chartbook and open a chart for the EUREX symbol that you want. Refer to: Chartbooks (Workspaces) Or use a separate instance: Using DTC Server for Data and Trading in Another Sierra Chart Instance Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
