Date/Time: Mon, 10 Feb 2025 16:24:31 +0000
Historical Data, version 2158
View Count: 542
[2020-08-25 14:44:42]
Tony - Posts: 549
After I upgrade to 2158, I noticed the message "Downloading historical data.." appears periodically on the screen and sometimes a bar was missing (gap between 2 bars) while data was streaming from IB, couple times, the streaming was halted completely, I had to disconnect and reconnect before streaming started again.
When I selected "Delete All Data and Download" under Edit menu, it always failed or just downloaded 1-2 weeks of data and stop (ES Sep. contract). My solution right now is running my 2156 copy, download data (never failed) and copy it to 2158's data folder.
Not sure if there are any settings I didn't do right in 2158?
Thanks.
Date Time Of Last Edit: 2020-08-25 20:03:50
[2020-08-26 00:42:36]
We can only refer you to:
And:
