Date/Time: Mon, 05 Oct 2026 13:01:55 +0000
Market Depth Historical Graph feature request.
View Count: 1341
[2020-08-25 13:07:46]
Darksound - Posts: 56
Any chance to have the ability to choose "Maximum quantity for coloring" between actual or percent. We can already do so for "Graph only quantities greater or equal to".
Thank you.
[2020-09-15 15:12:24]
John - SC Support - Posts: 48095
We have added this capability and it will be available in the next release (v 2169). So you will now be able to select both the Highest and the Lowest quantity for coloring based on either an Actual Value or a Percentage of the Maximum Depth.
[2020-09-15 15:17:25]
User472511 - Posts: 19
Is it possible to also add a filter to only display quantity numbers greater than a certain value (Actual or Percentage based)?
[2020-09-15 15:24:49]
WRT Post #3, that is already there. It is currently called Graph Only Quantities Greater or Equal to. We have changed the name in the next update to be Lowest Quantity for Coloring.
In either case, it allows you to specify the lowest value that will be colored by either an Actual Value or a Percentage of the Maximum depth.
Refer to the information here:
Market Depth Historical Graph: Lowest Quantity for Coloring
[2020-09-15 15:26:51]
I am specifically referring to the quantity numbers text. I want to display all depth levels, but only have the quantity numbers displayed for a certain threshold if that makes sense.
[2020-09-15 15:31:24]
That is only supported in the same manner using the Lowest Quantity for Coloring. It will not display the text or the background coloring.
We currently do not have an option to filter just the text.
[2020-09-15 16:05:32]
Yes; this is understood. I was simply asking if you could consider this filter as an option in the future. Thank you for your responses.
