Date/Time: Mon, 10 Feb 2025 14:50:56 +0000
Unable to download
View Count: 489
[2020-08-25 00:30:40] |
User352006 - Posts: 1 |
Good day, I am a Rithmic data user from AMP. I was referred to this thread: Rithmic Bridge Files and Updated TLS Certificate Files Needed for June 1, 2020 and Onward to fix my connection issue. In the thread it references a download to fix the /rim folder: https://www.sierrachart.com/Download.php?Folder=SupportBoard&download=39787 and I am getting an access denied error. I was hoping that I could get assistance on getting the file? Regards, |
[2020-08-25 04:54:02] |
We have discontinued all support for Rithmic. We recommend using the Sierra Chart Order Routing Service: Sierra Chart / Trading Technologies Futures Order Routing Service Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
