Date/Time: Mon, 10 Feb 2025 16:07:43 +0000
AMP Setup
View Count: 651
[2020-08-24 17:53:25]
Ben A - Posts: 123
I have registered with AMP as a new Broker and it has been several days since. When I asked them about credentials they said I need to email Sierra.
Is there anything I need to do additionally?
Thank you
Ben
[2020-08-24 17:59:11]
Sierra Chart - Max - Posts: 5789
Will you be using your direct Sierra Chart account, or an AMP provided Sierra Chart account?
Sierra Chart Support
[2020-08-24 18:04:36]
Ben A - Posts: 123
I currently have Denali + Sierra (through Sierra) and IB. I am switching broker to AMP, so I selected on their form using Sierra direct which I hope is correct...
Date Time Of Last Edit: 2020-08-24 23:02:13
[2020-08-25 04:35:20]
Complete this form:
https://www.sierrachart.com/UserControlPanel.php?page=SCOrderRoutingServiceTradingAccountAssignmentRequestForm
[2020-08-25 10:58:42]
Ben A - Posts: 123
Thanks, I have done this.
Can you confirm the costs are the same for Denali+Sierra if I go through you directly or through AMP?
Thanks,
Ben
Date Time Of Last Edit: 2020-08-25 11:02:22
[2020-08-26 00:34:13]
Yes the costs are the same.
Date Time Of Last Edit: 2020-08-26 00:34:18
