Date/Time: Mon, 16 Sep 2024 19:08:38 +0000
Remaining time for completing bar
View Count: 2823
[2014-02-03 17:26:00] |
User40117 - Posts: 56 |
hello, my previous charting software had a little 'clock'(in fact just a circle that is filled) according the time remaining for the bar to complete. Is it possible to be able to see this in SC or maybe an ACSIL way ? ty |
[2014-02-03 19:56:02] |
Sawtooth - Posts: 4091 |
You can add the Bar Countdown to the Chart Header: Global Settings >> Customize Chart Header And/Or you can add the CountDown Timer study to the chart. |
[2014-02-03 20:28:19] |
Use the Countdown Timer study: http://www.sierrachart.com/index.php?l=doc/doc_TechnicalStudiesReference.html#s201 Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
