Date/Time: Sat, 06 Jun 2026 21:20:57 +0000
Data connection failed (Rithmic)
View Count: 792
[2020-08-24 16:33:25]
User600210 - Posts: 1
Can you assist with the following. I cannot connect to data provider. I've copied the error log below. Many thanks.
Reading Internal Order ID file. | 2020-08-23 16:45:25.765
Reading Trade Orders file. | 2020-08-23 16:45:26.016
Reading Trade Positions file. | 2020-08-23 16:45:26.017
Reading Account Balance file. | 2020-08-23 16:45:26.017
UDPListener (1328). Port 22904 | Listening on UDP port 22904. | 2020-08-23 16:45:26.048
Software version: 2150 64-bit | 2020-08-23 16:45:26.048
Primary Thread ID: 137380 | 2020-08-23 16:45:26.048
Enabled for: Sierra Chart Historical Data Service. | 2020-08-23 16:45:26.048
Enabled for: Delayed Denali Real-Time Exchange Data Feed. | 2020-08-23 16:45:26.048
Allow Support for Sierra Chart Data Feeds is enabled. | 2020-08-23 16:45:26.048
Current selected Data/Trading service: Rithmic Trading | 2020-08-23 16:45:26.048
Custom symbol settings values: enabled | 2020-08-23 16:45:26.048
Chart Update Interval: 500 | 2020-08-23 16:45:26.048
Intraday Data Storage Time Unit: 1 | 2020-08-23 16:45:26.048
Time Zone: +08:00:00 (HKT+08) | 2020-08-23 16:45:26.048
2020-08-23 16:45:26 Local computer time | 2020-08-23 16:45:26.048
2020-08-23 08:45:26 Local computer time in UTC | 2020-08-23 16:45:26.048
2020-08-23 16:45:26 Local computer time in SC Time Zone | 2020-08-23 16:45:26.048
2020-08-23 08:45:26 Server time in UTC | 2020-08-23 16:45:26.048
Local computer UTC time and Server UTC time difference: 2 seconds. | 2020-08-23 16:45:26.048
Program path: C:\SierraChart\ | 2020-08-23 16:45:26.048
Data Files path: C:\SierraChart\Data\ | 2020-08-23 16:45:26.048
OS Version Number: 10.0 | 2020-08-23 16:45:26.048
Locale Setting: C | 2020-08-23 16:45:26.048
DLLs: UserContributedStudies.dll, UserContributedStudies_64.dll | 2020-08-23 16:45:26.048
Allowed protected custom studies: | 2020-08-23 16:45:26.048
Checking for new symbol settings. Requested symbol settings MD5 for service code rithmic.trading. Request ID: 1. | 2020-08-23 16:45:26.076
HTTPS connection ID:1 to login.sierrachart.com:443 for request ID:1 (1) | Shutdown started. Waiting for graceful close. | 2020-08-23 16:45:26.179
HTTPS connection ID:1 to login.sierrachart.com:443 for request ID:1 (1) | Socket gracefully closed by remote side. | 2020-08-23 16:45:26.441
HTTPS connection ID:1 to login.sierrachart.com:443 for request ID:1 (1) | Closed. | 2020-08-23 16:45:26.441
Received 5 login tokens. | 2020-08-23 16:45:26.874
Symbol settings MD5 received. Request ID: 1. | 2020-08-23 16:45:27.250
Symbol settings are up-to-date for rithmic.trading. | 2020-08-23 16:45:27.250
Files to Open on Start up | Opening file: ExampleChartbook.cht | 2020-08-23 16:45:30.171
ESU0-CME 5 Min #11 | Reloading chart. | 2020-08-23 16:45:30.218
ESU0-CME 1000 Volume #1 | Reloading chart. | 2020-08-23 16:45:30.245
ESU0-CME #3 | Reloading chart. | 2020-08-23 16:45:30.525
ESU0-CME #3 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2020-08-23 16:45:30.525
ESU0-CME 1000 Volume #1 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2020-08-23 16:45:30.564
Rithmic Trading | Port for executable: 52803 | 2020-08-23 16:45:32.552
Listening socket (1380). Port 52803 | Closed. | 2020-08-23 16:45:32.552
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2020-08-23 16:45:32.555
Created process C:\SierraChart\Rim\DTCBridge.exe. Current folder: C:\SierraChart\Rim | 2020-08-23 16:45:32.580
Rithmic Trading | Bridge process is running. | 2020-08-23 16:45:34.597
Rithmic Trading | Connecting to the server 127.0.0.1. Port 52803 | 2020-08-23 16:45:34.597
DTC Client socket (1) | Creating socket. | 2020-08-23 16:45:34.597
DTC Client socket (1) | Connecting to IP: 127.0.0.1. | 2020-08-23 16:45:34.597
Rithmic Trading | Connected to server. | 2020-08-23 16:45:34.600
Rithmic Trading | Starting socket receive thread. | 2020-08-23 16:45:34.600
Rithmic Trading | Sending encoding request to server: Binary VLS | 2020-08-23 16:45:34.600
Rithmic Trading | Setting DTC encoding to Binary VLS | 2020-08-23 16:45:34.604
Rithmic Trading | Sending logon request message. | 2020-08-23 16:45:34.604
Rithmic Trading | Message from server: Starting the connection process to data and trading service. | 2020-08-23 16:45:34.608
Rithmic Trading | Message from server: Logging is enabled. Log file: C:\SierraChart\Rim\Rithmic.log | 2020-08-23 16:45:34.618
Rithmic Trading | Message from server: Connecting to Rithmic Singapore server. | 2020-08-23 16:45:34.618
Rithmic Trading | Message from server: Server Alert: Market Data Connection Broken | 2020-08-23 16:45:44.019
Rithmic Trading | Message from server: Server Alert: Trading System Connection Broken | 2020-08-23 16:45:46.548
Rithmic Trading | Received logon response. | 2020-08-23 16:45:46.548
Rithmic Trading | Server Name: DTC Bridge. | 2020-08-23 16:45:46.548
Rithmic Trading | Server protocol version: 8. Client protocol version: 8 | 2020-08-23 16:45:46.548
Rithmic Trading | Logon error received from server | 2020-08-23 16:45:46.548
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2020-08-23 16:45:46.548
Select 'File >> Disconnect' to prevent further connection attempts. | 2020-08-23 16:45:46.548
Rithmic Trading | Waiting for socket receive thread to end | 2020-08-23 16:45:46.655
DTC Client socket (1) | CloseSocket call. | 2020-08-23 16:45:46.655
Rithmic Trading | Disconnected. | 2020-08-23 16:45:46.656
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-08-23 16:45:46.656
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2020-08-23 16:45:46.656
Rithmic Trading | Port for executable: 52817 | 2020-08-23 16:45:48.669
Listening socket (1384). Port 52817 | Closed. | 2020-08-23 16:45:48.669
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2020-08-23 16:45:48.671
Created process C:\SierraChart\Rim\DTCBridge.exe. Current folder: C:\SierraChart\Rim | 2020-08-23 16:45:48.686
Rithmic Trading | Bridge process is not running! | 2020-08-23 16:45:50.708
Rithmic Trading | Connecting to the server 127.0.0.1. Port 52817 | 2020-08-23 16:45:50.708
DTC Client socket (2) | Creating socket. | 2020-08-23 16:45:50.708
DTC Client socket (2) | Connecting to IP: 127.0.0.1. | 2020-08-23 16:45:50.708
DTC Client socket (2) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2020-08-23 16:45:52.750 *
DTC Client socket (2) | CloseSocket call. | 2020-08-23 16:45:52.750
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2020-08-23 16:45:52.750
Select 'File >> Disconnect' to prevent further connection attempts. | 2020-08-23 16:45:52.750
DTC Client socket (2) | Closed. | 2020-08-23 16:45:52.750
DTC Client socket (0) | CloseSocket call. | 2020-08-23 16:45:52.765
Rithmic Trading | Disconnected. | 2020-08-23 16:45:52.765
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2020-08-23 16:45:52.765
Rithmic Trading | Port for executable: 52819 | 2020-08-23 16:45:54.773
Listening socket (1384). Port 52819 | Closed. | 2020-08-23 16:45:54.773
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2020-08-23 16:45:54.775
Created process C:\SierraChart\Rim\DTCBridge.exe. Current folder: C:\SierraChart\Rim | 2020-08-23 16:45:54.792
Rithmic Trading | Bridge process is not running! | 2020-08-23 16:45:56.802
Rithmic Trading | Connecting to the server 127.0.0.1. Port 52819 | 2020-08-23 16:45:56.802
DTC Client socket (2) | Creating socket. | 2020-08-23 16:45:56.802
DTC Client socket (2) | Connecting to IP: 127.0.0.1. | 2020-08-23 16:45:56.802
File >> Disconnect selected. | 2020-08-23 16:45:57.981
DTC Client socket (2) | CloseSocket call. | 2020-08-23 16:45:57.981
Rithmic Trading | Disconnected. | 2020-08-23 16:45:57.981
DTC Client socket (2) | Closed. | 2020-08-23 16:45:57.981
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-08-23 16:46:07.737
DTC Client socket (1) | Closed. | 2020-08-23 16:46:07.737
[2020-08-25 04:51:04]
We have discontinued support for Rithmic:
Regarding Rithmic (Our Final Post on this Subject)
