Date/Time: Mon, 10 Feb 2025 14:33:55 +0000
Denali Datafeed
View Count: 478
[2020-08-24 16:27:44] |
ambtn723 - Posts: 14 |
I posted this request previously and got a link to a page talking about how various feeds offer different types of data and each feed may be slightly different than the other. I'm finding my Denali feed is drastically different. I'm looking at volume and the analytics I gather from volume data, and it's wrong at critical levels that I use to calculate my ideas off of. For example, using market profile, value areas today (8/24) are being calculated using my feed at 3388 for the Friday levels. General consensus is the high level is at 3391 (this is based off of twitter and a few other online sites). overnight volume point of control on my feed is 3421. Consensus has it down to 3416. Given the disparity my stops/positions are going negative way too often. Is this a Denali only problem? I notice that many of the other users whose accounts I follow use CQG. How can I switch my feed to that? |
[2020-08-25 04:48:56] |
The Denali data feed is definitely fine. However, make sure Sierra Chart is set for a tick by tick data configuration. Set Sierra Chart to a Tick by Tick Data Configuration. Follow the instructions here to do this: Tick by Tick Data Configuration And for Help with this specific issue, refer to: Time Price Opportunity (TPO) Profile Charts: Incorrect Value Area or Point of Control Values Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2020-08-25 04:49:23
