Date/Time: Mon, 10 Feb 2025 15:16:01 +0000
[Programming Help] - Strange optical bug
View Count: 437
[2020-08-24 14:11:15]
Jens Albrecht - Posts: 2
I built a percentage-based comparison of S&P sectors. I used "Add Additional Symbol" and "Percent Change since Open" Studies as described in the documentation.
It worked for some time without problem. But since a few weeks the graph shows an annoying bug. See screenshot. There is always an "up-hook" at the end of the chart. The DLY data files look ok.
I just upgraded to version 2158. Kept the same.
Regards, Jens
imageBildschirmfoto 2020-08-24 um 15.58.48.png / V - Attached On 2020-08-24 14:09:54 UTC - Size: 565.56 KB - 211 views
