Date/Time: Mon, 10 Feb 2025 15:02:01 +0000
chartbook wont load
View Count: 521
[2020-08-24 09:27:22] |
Robert Wojczak - Posts: 147 |
My chart books wont load can I send you the message log
Date Time Of Last Edit: 2020-08-25 00:29:21
sierra no load.PNG / V - Attached On 2020-08-24 09:26:02 UTC - Size: 73.54 KB - 179 views |
[2020-08-25 00:28:36] |
Refer to this section here: High CPU Usage | Inactive User Interface | Poor Performance | Long Time to Load Chart Data | Charts Reloading Often: 30.16 - What to do if Sierra Chart is in a frozen state for an extended time due to extended high CPU usage caused by an automatically or manually opened Chartbook And enable Safe Mode: Sierra Chart - Software Login Instructions: Using Safe Mode if you still have trouble we recommend you start with a new Chartbook. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
