Date/Time: Mon, 10 Feb 2025 14:44:00 +0000
[Programming Help] - s_SCBasicSymbolData has no more member Symbol
View Count: 548
[2020-08-24 07:26:16] |
TedMar - Posts: 190 |
Hi, i try to recompile my sources on last SC reales 2158, i got error from compiler like s_SCBasicSymbolData has no more member Symbol. How to resolve this problem? |
[2020-08-24 07:32:53] |
You need to instead use sc.Symbol. If you have requested the Symbol Data for a different symbol than the symbol of the chart, then you will know what symbol it is for without even accessing this removed structure member.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2020-08-24 07:33:19
