Date/Time: Mon, 10 Feb 2025 14:59:16 +0000
ASX equities via IB
View Count: 26396
[2020-08-24 00:18:47] |
vish100 - Posts: 111 |
Hi, I know that SC does not provide ASX (Australia) feed yet. But if I am connected to IB (in Australia), then can the ASX stocks be charted/used in SC piggy backing on the IB connection? thanks |
[2020-08-24 02:19:30] |
Yes.
[2020-08-24 02:35:52] |
How can I do that? When I go to 'Find' in 'Chart Settings' there is no ASX stocks etc. there. I can see HK stocks though. thx |
[2020-08-25 04:25:05] |
Refer to: Interactive Brokers Symbols Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
