Date/Time: Mon, 10 Feb 2025 15:10:19 +0000
c_VAPContainer, sc.BaseData, s_CustomChartBarInterface Interface
View Count: 529
[2020-08-23 12:04:01] |
Ackin - Posts: 1865 |
to SC Support) 1) Could you please consider adding new items to the c_VAPContainer object? Last value volume_ask and Last value volume_bid (meaning last trade at this time). or better: add it to sc.BaseData 2) s_CustomChartBarInterface Interface is there a way to add user Subpgraph there? Thanks Date Time Of Last Edit: 2020-08-24 07:17:08
[2020-08-25 04:27:12] |
1. This breaks compatibility with existing studies doing this, and it also increases the amount of memory use. So what seems like to you a simple request is something that will cause major issues and complaints. We definitely cannot do this. 2. You already have access to all the Subgraphs used by the main base graph with this function: s_CustomChartBarInterface::GetChartBarValue Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
