Date/Time: Tue, 15 Sep 2026 11:01:54 +0000
ACSIL build complains about SCDLLName duplicate
View Count: 1440
| [2020-08-22 16:51:19] |
| User806682 - Posts: 25 |
Hi, When building a study using two or more files and having one file declare the SCDLLName("--name--") and another file using the variable sc.IsUserAllowedForSCDLLName - the build throws the following error: "More than one of the selected source files contains the SCDLLName line at the top of the file. Only one file can contain SCDLLName." Is it possible to fix this? I'd like to have a shared function that tests user access instead of having this duplicate code on each file. Thank you. |
| [2020-08-23 05:33:56] |
Yes we will resolve. We will revise the current version and release in about an hour.
