Date/Time: Mon, 10 Feb 2025 14:56:05 +0000
PC crash- need to reinstall
View Count: 553
[2020-08-22 16:06:50]
User404901 - Posts: 11
Hello, I will likely need to purchase a new PC and will need to re-install. I see I have 2 systems available, how can I deactivate the original one from the crashed PC?
thank you
[2020-08-23 01:10:27]
This concept does not exist with Sierra Chart. There is nothing special you need to do.
To copy your existing installation refer to:
Transferring Sierra Chart Settings and Data From Existing Installation to New Installation
