Date/Time: Mon, 10 Feb 2025 14:34:13 +0000
v2156 Release All DLLs and Deny Load - not working
View Count: 504
[2020-08-22 13:02:44] |
binaryduke - Posts: 377 |
v2156 menu option Analysis/Build Advanced Custom Studies DLL/Build/Release All DLLs and Deny Load (and single DLL) does not appear to be working. DLL remains in use by SC.
[2020-08-22 20:33:25] |
Ackin - Posts: 1865 |
binaryduke) Do you have a library with "_2151_64" in the name?
Date Time Of Last Edit: 2020-08-22 21:02:28
[2020-08-22 21:25:23] |
We are checking on this.
[2020-08-23 01:46:41] |
We cannot reproduce any problem with this. Check the Message Log and see if the DLL gets unloaded. Provide us the message log from the point where the DLL is loaded to the point where you use this command and it is unloaded. We will have to add more logging to isolate the issue. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
