Date/Time: Sat, 28 Nov 2026 03:02:34 +0000
Gap Zones
View Count: 3434
| [2014-02-03 13:55:01] |
| User33552 - Posts: 23 |
You have GapZonesAfterDownDay and GapZonesAfterUpDay. They do not show the times I'd like to have shown and I'd like to have some additional possibilities. How would I do that? Do you write them for me or do you make some sort of "scripting" available to users? I'm a long term member of "Master The Gap" trading room. (MTG)Presently I use two systems and am trying to go to Inifinity/Sierra. In my present charts (Thinkorswim)I have things I use every day and I'd like to start using Sierra but need the "indicators." Here are things I'd like to write "scripts" for and add to my Sierra possibilities: 1. Both of your current GapZones** inicators start at midnight. I'd like them to chart at the cash open and show the zones/numbers for cash close for ES, TF, NQ, YM. 2. I currently have a colored area that shows the remaining gap zone and that area diminishes as the zone fills giving me a visual or the remaining gap. 3. I have boxes at the top of the page showing a. the name of the zone: b. the name of another "warning" signal 4. I have the zones indicated by lines as your GapZones** show. 5. I have an indicator that draws a line at the end of the first hour showing first hour high and low for this day Screenshots attached showing what I currently use. |
| [2014-02-03 16:46:14] |
GapZonesAfterDownDay and GapZonesAfterUpDay are not studies developed by Sierra Chart. They must be from some outside developer. Could you please contact that developer about these requests.
| [2014-02-04 13:09:52] |
Thank you...that is what I was asking for in my second line..."How?" How do I get access to have the ability to develop scripts/code I can integrate into Sierra? 1. Can you tell me who the developer is or how to contact that developer? (I have no way of knowing that. I only know it is an option in the charts.) 2. If I want to write something like this for myself, can you tell me how to "gain access" to the program in order to be able to write the code? (Are there scripts available that integrate with Sierra, etc?) |
| [2014-02-04 15:52:10] |
1. We are not sure how to contact the developer because we do not know who they are. 2. Refer to the documentation here: http://www.sierrachart.com/index.php?l=doc/doc_CreatingDLLs.html All the related documentation links can be found here: http://www.sierrachart.com/index.php?l=doc/doc_Contents.php#AdvancedCustomStudySystemInterfaceandLanguage Sierra Chart Support Date Time Of Last Edit: 2014-02-05 09:52:06
