Date/Time: Tue, 11 Feb 2025 08:32:29 +0000
How can I display PnL in ticks on the chart
View Count: 1916
[2020-08-22 06:53:54]
vish100 - Posts: 111
I know how to show order fills on the chart.
How can I display PnL in ticks on the chart let's say for ES futures?
thanks
[2020-08-25 00:42:06]
Refer to this setting:
Chart Settings: Profit/Loss Format (List) (Chart >> Chart Settings >> Trading menu)
[2020-08-25 06:11:10]
I did not mean on the trade order line. I meant for 'shown order fills' on the chart
Date Time Of Last Edit: 2020-08-25 08:09:01
[2020-08-26 00:43:40]
We gave you the right setting but also refer to this setting:
Global Trade Settings Windows: Display Trade Profit/Loss (Global Settings >> Chart Trade Settings >> Order Fills >> Order Fills)
Date Time Of Last Edit: 2020-08-26 00:43:46
[2020-09-02 23:27:56]
Thanks. This works!
Now I am also using the 'display entry/exit connecting' lines setting.
However the issue is that the connecting line is too thin and it's hard for me to see the connecting order lines, esp when there are too many orders in a particular area.
Is it possible to increase the width/font of this entry/exit connecting lines so they are better visible?
thanks
Vish
[2020-09-03 14:22:21]
John - SC Support - Posts: 37869
Refer to the following Graphics Setting and the one after it:
Customizing Fonts, Colors, Line Styles, and Widths for Chart Trading, Chart DOM, and Trade DOM: Chart Trading Order Fill Entry/Exit Connecting Lines Primary
