Date/Time: Mon, 10 Feb 2025 14:42:44 +0000
Sierra Chart doesen´t save Chartbooks
View Count: 498
[2020-08-21 21:22:28] |
User463623 - Posts: 1 |
Hi, if i create a new Chartbook, named and save it, its not saved. I cant find and open the chartbook in Sierra and not in the Datafolder. Changes in my actually Chartbook are saved, but not new greated Chartbooks. Does anybody know where is the problem? greetings Tobi |
[2020-08-22 08:36:59] |
Check the Window >> Message Log for any error message when you save the Chartbook to see what the problem is. Your Sierra Chart account which you have logged into this Support Board with is expired. So we know what Sierra Chart account you are using, go to Help >> Support Board from within the Sierra Chart desktop program and then post in this thread telling us this is done. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
