Date/Time: Mon, 10 Feb 2025 01:38:31 +0000
Time Zone Settings
View Count: 635
[2020-08-21 19:09:10] |
UserV-Werks - Posts: 4 |
I'm using the TPO (Market Profile) charts and I can't get the TPOs (A,B, C...) to sequence correctly. I've set the both the globlal settings, and the PC I'm running on set to Eastern Time. How do I get the TPOs (30 minute increments) to begin with A period at 9:30 Eastern and end with N period at 4:15 Eastern? Thank you.
[2020-08-21 19:38:45] |
Do check the time zone specifically for the chart: Time Zone Setting: Using Different Time Zone in Individual Charts And also refer to: Time Price Opportunity (TPO) Profile Charts: Customize TPO Letters Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2020-08-21 19:38:57
