Date/Time: Thu, 28 Nov 2024 01:45:30 +0000
[Locked] - Does Sierra´s DOM Have Snapshot Feature?
View Count: 1137
[2020-08-21 12:16:53] |
User336770 - Posts: 30 |
@ SC Engineering: Does the DOM have this same feature of Jigsaw called "snapshot"? What it is: whatever number of limit orders that was resting at a level gets frozen when price arrives, so you can see if orders are being added or pulled from it, then if price ticks up or down and move away from the level, the value just resets and show the current value. (it is the same row that shows orders being pulled and stacked, but the value freezes when price gets there). I have attached an image explaining. Regards |
DOM jigsaw.png / V - Attached On 2020-08-21 12:15:51 UTC - Size: 1.46 MB - 863 views |
[2020-08-21 19:18:01] |
No. There are market depth pulling and stacking columns available: Global Trade Settings Windows: Chart/Trade DOM Column Descriptions And also the sum of the pulling and stacking columns is provided as well. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2020-08-21 19:22:19
[2020-08-22 12:06:22] |
I noticed, was more interested in the snapshot feature. Is that a feature that will be added in a future update?
[2023-06-11 08:44:05] |
User220637 - Posts: 10 |
Why I can t open 5 min futures chart? Does my package support that? If not, what package do I need for FUTURES? Thank you
[2023-06-11 14:01:33] |
Sierra_Chart Engineering - Posts: 17199 |
This thread is now locked. Your posting is not related to this thread. Start a new Support Request: Support Board Posting Information Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
