Date/Time: Mon, 10 Feb 2025 15:11:48 +0000
Custom Study not available anymore inspite of having the newest version of sierrachart
View Count: 686
[2020-08-21 10:09:23] |
User264564 - Posts: 10 |
Hello, i have a custom Study (ECIVwap) which is not showing anymore. I attached a Screenshot with the Issue. It says "requires SierraChart Version of 2149 or higher"; i have 2150. What might be the problem? thnak you and best |
[2020-08-21 10:23:17] |
Ackin - Posts: 1865 |
Look: ECI studies in custom studies is gone |
[2020-08-21 10:47:33] |
This will be resolved by updating to version 2156. Follow the instructions here: Software Download: Fast Update 2156 is the current version. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2020-08-22 22:25:58] |
What studies are you referring to? If you are referring to the user contributed studies supplied with Sierra Chart, those are working in 2156. Otherwise, refer to the information here: https://www.sierrachart.com/index.php?page=doc/Whats_New.php#SCVer2156 Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
