Date/Time: Mon, 10 Feb 2025 14:38:40 +0000
chart header bug in v.2156
View Count: 681
[2020-08-20 23:06:46] |
User814219 - Posts: 38 |
When creating a New Instance via File -> New Instance, the 'Description' Header Field option for the Chart Header does not display the Contract Name and Contract Month on charts. Previously it used to. In the main instance, it does display the Contract Name but does not display the Contract Month. Date Time Of Last Edit: 2020-08-20 23:12:46
[2020-08-21 00:35:52] |
We do not observe any problem with this. Can you provide a screenshot of what you see on the title bar of the chart.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2020-08-21 00:35:58
[2020-08-21 10:01:34] |
This is how the 'Description' Field in the Chart Header usually looks (v.2150): http://www.sierrachart.com/image.php?Image=1598003595693.png After updating to v.2156, in the MAIN INSTANCE, the 'Description' Field in the Chart Header suddenly doesn't show the Contract Month. (http://www.sierrachart.com/image.php?Image=1598003872990.png). You can in the screenshot how it suddenly doesn't include the word "September 2020." Also in v.2156, when I create a new instance via File->New Instance, the 'Description' Fields in the Chart Header not only do not show the Contract Month, it also does not show the Symbol either. (http://www.sierrachart.com/image.php?Image=159800405042.png) This is using the CQG webapi service. Date Time Of Last Edit: 2020-08-21 10:05:35
[2020-08-21 21:05:36] |
We will resolve this in the next release. Also in regards to not seeing the symbol you need to add that field by selecting Global Settings >> Customize Chart Header - Standard. Refer to the information here: Working With Charts: Region Data Line / Chart Header Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2020-08-21 21:09:13
