Date/Time: Mon, 10 Feb 2025 01:41:29 +0000
Change to package 5
View Count: 536
[2020-08-20 16:44:37]
jsmanuse - Posts: 32
I just found the volume by price indicator which is the reason I switched to package 5. Is this correct - that it is not available on package 3? thank you
[2020-08-20 19:50:24]
The Volume by Price study is available in Package 3, but the ability to use the tool option to draw the area for a Volume by Price profile is not (that is in Package 5). Refer to the information here:
Description of Service Packages and Pricing: Packages
To change your Sierra Chart Service Package, select "Help >> Account Control Panel" on the Sierra Chart program menu. On the displayed webpage, click on the "Set Service Package for Renewal" link.
Or go to this page:
https://www.sierrachart.com/UserControlPanel.php?page=ServicesActivation
You will need to login if you are not currently logged in.
In the "Available Services >> Choose Usage Time Service Package" frame, select the Service Package that you want to set your account to. Press the "Set" button.
The remaining service usage time on your account will be adjusted based upon the cost of the package you are changing to. If the new package is a higher-priced package, then the usage time will be reduced due to the higher price.
There is no charge for changing your Sierra Chart service package. Only your Sierra Chart account usage time ending date is adjusted.
