Date/Time: Thu, 06 Mar 2025 18:54:48 +0000
Limit the number of levels in the pull/stack sum?
View Count: 2716
[2020-08-20 16:28:29]
FuturesTradeKing - Posts: 13
Question, how many levels are included in this value? If the answer is ALL levels using the Denali feed, can you make a change to limit the number of levels?
Generally only 10-15 levels are needed to examine the book for local price changes. Including ALL levels will mean including very large target limit orders that sit in the book far awway from price.
image2020-08-18_09-45-27.png / V - Attached On 2020-08-20 16:28:03 UTC - Size: 63.68 KB - 505 views
[2020-08-20 20:02:30]
Due to the fact that the calculation is done in one central location, the only way to do that is with this setting:
https://www.sierrachart.com/index.php?page=doc/DataSourceSettings.php#MaxDepthLevels
Date Time Of Last Edit: 2020-08-20 21:49:43
[2020-08-20 20:26:41]
I am on the Deanali feed and I did try that setting today. No matter what I set it to, 10,25,50 it doesn't seem to matter in the numbers being displayed. Generally the pull/stack values "clear" whenever you make a change, but this time they stayed.
[2020-08-20 21:50:08]
We apologize. We had given you the wrong link. This is the setting you need to change:
Be sure to reconnect to the data feed after as the documentation explains.
Date Time Of Last Edit: 2020-08-20 21:50:15
[2021-06-24 00:28:16]
darkhorse3 - Posts: 1
I would see like to bid/ask full book (including all levels of mbo) - but see only 24 levels of pull/stack with sum - how do we do this? In all areas of market data settings i've located - when i limit to 24 it limits the FULL BOOK to 24. I've read thru the above link and there is nothing that addresses.
Date Time Of Last Edit: 2021-06-24 00:38:36
imagelimitpullstack.png / V - Attached On 2021-06-24 00:26:07 UTC - Size: 57.7 KB - 352 views
[2021-06-24 14:23:57]
John - SC Support - Posts: 38446
This is the setting you need:
Global Trade Settings Windows: Maximum Bid/Ask Market Depth Pulling/Stacking Levels (Global Settings >> Chart DOM Settings >> Other >> Other Settings)
[2021-08-26 02:30:35]
Atmos37 - Posts: 11
Can this setup be duplicated on the Trade DOM? can't find the setting for pulling/stacking totals on there.
[2021-08-26 04:14:22]
There is no setting but the Market Depth Pulling and Stacking totals are shown above and below the Pulling and Stacking data on the Trade DOM.
You just need to scroll the values into view:
The Chart DOM Scale: Interactive Scale Move
Date Time Of Last Edit: 2021-08-26 04:15:05
[2022-02-10 17:07:28]
whats1thingnow - Posts: 407
from post #6
Global Trade Settings Windows: Maximum Bid/Ask Market Depth Pulling/Stacking Levels (Global Settings >> Chart DOM Settings)
does the global settings apply to the Numbers Bars Calculated values 2, or just the dom?
Sum Bid Pull/Stack: This displays the sum of all of the Bid side market depth pulling and stacking values. Only the value at the very last chart column is updated for this Subgraph. At least one of the Pulling/Stacking columns needs to be displayed in the DOM in order to see this subgraph information.
Sum Ask Pull/Stack: This displays the sum of all of the Ask side market depth pulling and stacking values. Only the value at the very last chart column is updated for this Subgraph. At least one of the Pulling/Stacking columns needs to be displayed in the DOM in order to see this subgraph information.
is it possible to have difference stack/pull levels for each chart?
e.g. using settings > advanced settings 3 > number of levels for bid/ask depth calculations:
- i use 5 for ES chart so stack/pull levels are only 5 levels in Numbers Bars Calculated values 2?
- i use 15 for YM chart so stack/pull levels are 15 levels in Numbers Bars Calculated values 2?
thank you
[2022-02-10 17:58:50]
The Numbers Bars Calculated Values 2 subgraphs for the Pulling/Stacking use the data as it is displayed in the DOM. So if the number of levels is limited, it will only show the information for the limited data.
