Date/Time: Sat, 19 Sep 2026 11:21:19 +0000
Want to configure life feed for CME without a live trading account
View Count: 787
| [2020-08-20 15:21:55] |
| User763614 - Posts: 2 |
Hi! I am trying to configure the live feed for CME without a live trading account and I am finding it hard to find the correct steps to take. I theoretically need CME, NYMEX and COMEX however i do not have a live account because most of the brokers need a wire transfer while I can only atm do card transactions. Could you help me configure CME for professional which is think is around 110 dollars a month, i have already funded the Sierra Account with enough funds to do so. Best regards Nikita |
| [2020-08-20 17:05:57] |
First, we recommend looking at the following solution to your Trading Account issue. We do not know if they require a wire transfer, but we do not want you paying the additional Professional fees if you can find a way to not do so: Easy Solution to CME Funded Trading Account Requirement If you still want to proceed as a Professional trader, then follow the Setup Instructions on the Denali Exchange Data Feed page here: Denali Exchange Data Feed: *Setup Instructions: CME/CBOT/NYMEX/COMEX Exchanges* The one thing you need to be aware of is that when filling out the Exchange Agreements, you need to leave the fields for "Clearing Firm", "Account Number", and "Salesperson" blank in the Uniform Market Data Subscriber Agreement, and then be sure you select the "No" button in the CME Non-Professional Certification agreement. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
