Date/Time: Mon, 10 Feb 2025 01:56:30 +0000
SierraChart & Denali Data Feed all services possible to use for 3rd party price ladder?
View Count: 622
[2020-08-19 17:00:46] |
Stephan_CH - Posts: 18 |
Hello I have subscribed SierraChart and Denali Datafeed for all services. I'm using outside of SC the Jigsaw daytradr price ladder for ordering with Rithmic data feed. My question: how can I use the same datafeed respectively the second or third feed to connect Jigsaw priceladder with my in SC subscribed service for live trading and Sim. It's not because the money for the separate datafeed - I know it's not possible to use a connection twice - but it's a matter of one Service Provider. Would very appreciate if I could get all from one hand, and I'm very satisified with the service you provide. I would prefer to pay more to one service provider. Thanks a lot for your help. Kind regards, Stephan |
[2020-08-19 20:23:53] |
This is not supported.
