Date/Time: Wed, 23 Sep 2026 10:50:42 +0000
Frequent disconnects
View Count: 877
| [2020-08-19 16:17:58] |
| User996502 - Posts: 28 |
Ok I have switched to Sierra Chart Order Routing service with Denali and I am having same disconnect issues. Here is the log: DTC Client socket (2) | Socket gracefully closed by remote side. | 2020-08-19 08:47:28.425 DTC Client socket (2) | Close event error. Windows error code 10053: An established connection was aborted by the software in your host machine. | 2020-08-19 08:47:28.425 * DTC Client socket (2) | CloseSocket call. | 2020-08-19 08:47:28.425 Connection to the external service has been lost. | 2020-08-19 08:47:28.425 DTC Client socket (2) | Write in progress. Shutdown being delayed. PendingSize=0 | 2020-08-19 08:47:28.425 SC Futures Order Routing/Data | Waiting for socket receive thread to end | 2020-08-19 08:47:28.439 DTC Client socket (0) | CloseSocket call. | 2020-08-19 08:47:28.439 SC Futures Order Routing/Data | Disconnected. | 2020-08-19 08:47:28.439 Will reconnect to the server in 1.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2020-08-19 08:47:28.439 DTC Client socket (2) | Write has completed. Shutdown being performed. | 2020-08-19 08:47:29.128 DTC Client socket (2) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2020-08-19 08:47:29.128 DTC Client socket (2) | Closed. | 2020-08-19 08:47:29.128 SC Futures Order Routing/Data | Connecting to the server futurestrading2.sierracharts.com. Port 11098 | 2020-08-19 08:47:29.439 DTC Client socket (2) | Creating socket. Using TLS 1.2. | 2020-08-19 08:47:29.488 DTC Client socket (2) | Connecting to IP: 208.185.224.129. | 2020-08-19 08:47:29.488 SC Futures Order Routing/Data | Connected to server. | 2020-08-19 08:47:29.541 SC Futures Order Routing/Data | Starting socket receive thread. | 2020-08-19 08:47:29.541 SC Futures Order Routing/Data | Sending encoding request to server: Binary VLS | 2020-08-19 08:47:29.541 SC Futures Order Routing/Data | Setting DTC encoding to Binary VLS | 2020-08-19 08:47:29.671 SC Futures Order Routing/Data | Sending logon request message. | 2020-08-19 08:47:29.671 SC Futures Order Routing/Data | Received logon response. | 2020-08-19 08:47:29.717 SC Futures Order Routing/Data | Server Name: SC DTC Server. | 2020-08-19 08:47:29.717 SC Futures Order Routing/Data | Server protocol version: 8. Client protocol version: 8 | 2020-08-19 08:47:29.717 SC Futures Order Routing/Data | Successfully connected. Connected to SC DTC Protocol server. Service=trading_technologies.trading|SymbolSettings=trading_technologies_v2.trading. | 2020-08-19 08:47:29.717 SC Futures Order Routing/Data | Trading is supported. | 2020-08-19 08:47:29.717 SC Futures Order Routing/Data | Order cancel and replace is supported. | 2020-08-19 08:47:29.717 SC Futures Order Routing/Data | OCO Orders supported. | 2020-08-19 08:47:29.717 SC Futures Order Routing/Data | Bracket Orders supported. | 2020-08-19 08:47:29.717 SC Futures Order Routing/Data | Connected to server. | 2020-08-19 08:47:29.717 Triggering next historical data download in queue. | 2020-08-19 08:47:29.717 Triggering next historical data download in queue. | 2020-08-19 08:47:29.717 Triggering next historical data download in queue. | 2020-08-19 08:47:29.717 Triggering next historical data download in queue. | 2020-08-19 08:47:29.717 Updated verified funded futures trading account ending date to: 2020-09-18 12:47:30 | 2020-08-19 08:47:29.717 |
| [2020-08-19 19:55:48] |
Therefore this is going to be due to your Internet connection. What is the time zone of the timestamps we see above? You may also want to try a different server. Try using Server 1 as the Primary Server. Refer to step 11 here: https://www.sierrachart.com/index.php?page=doc/SierraChartOrderRoutingServiceWithData.php#SetupInstructions Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
| [2020-08-20 01:15:19] |
I am in EST. Ive changed this to server 1 as primary but it still disconnects. DTC Client socket (1) | Close event error. Windows error code 10053: An established connection was aborted by the software in your host machine. | 2020-08-19 20:05:30.476 * |
| [2020-08-21 19:44:30] |
A single line from the Message Log does not give us enough of a context. We need to have the last few minutes of the Message Log. Make sure your connectivity is completely wired and not wireless. Do not use a wireless connection to the router. Also refer to: Prices / Data Falling Behind: 4.16 - Monitoring Sierra Chart Data Feed Performance from Perspective of Server Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2020-08-21 19:45:32
