Date/Time: Mon, 10 Feb 2025 01:30:26 +0000
Monthly and Weekly have excessive grid lines after update to pre-releas v.2154
View Count: 600
[2020-08-19 09:08:09] |
Frostation - Posts: 16 |
After updating to the pre-release Sierra Chart version "2154" all the grid's are no longer correct. These were much more spread out on version 2118 for example. I have attached a screenshot of what I mean. Please advise how to correct this. Update: For example I have checked the Advanced2 settings and the grid lines are set to weeks on the Monthly timeframe but the vertical gridlines are displaying per bar which is not correct. Date Time Of Last Edit: 2020-08-19 09:17:30
[2020-08-19 18:33:38] |
We will look into this and resolve.
