Date/Time: Tue, 06 Oct 2026 01:35:48 +0000
[Programming Help] - ASCIL: Setting SubGraphRef and the Lifetime of sc.Subgraph[] Arrays
View Count: 968
[2020-08-19 07:43:26]
BlakJak - Posts: 108
I have some code which stores an object for re-use using the GetPersistentPtr(). All that works fine and I have used it in many studies.
Recently I thought of adding members to the class as references to the Subgraphs for ease of access and readability in my code. However, it seems that those references when restored with a new call to the study (via GetPersistentPtr()) are pointing somewhere else as the [Subgraph].Name changes to garbage or "" (and eventually I get exceptions when writing data using those references).
What is the persistence of the Subgraph[] arrays in memory from call to call in the studies?
Should I be resetting my references with each new call to the study?
I am using pre-release 2154.
Date Time Of Last Edit: 2020-08-19 07:44:45
[2020-08-20 20:16:30]
Yes they cannot be remembered.
