Date/Time: Mon, 10 Feb 2025 01:36:28 +0000
chart values/crosshair
View Count: 778
[2020-08-19 00:51:21] |
User882732 - Posts: 4 |
Hello, I currently use the chart values/crosshair while I'm trading and the vertical line on the chart values/crosshair is bothering and I would like to know if there's a way to remove it ? The only line that i would like to show is the horizontal line. Please let me know if there's a way to remove the vertical line ?
[2020-08-19 20:10:35] |
Yes, you can remove the vertical line by turning off the option for Show Crosshair Vertical Line. Refer to the information in this section: Chart Drawing Tools: Chart Values Tool Configuration Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
