Date/Time: Mon, 10 Feb 2025 02:00:13 +0000
Value on High (Low) Draw Style problem when using Volume at Price Multiplier
View Count: 614
[2020-08-18 18:13:55]
ticinotrader - Posts: 401
Dear Support,
Can you please advise on the following topic:
I try to display the 'Bar Delta Below Bar' study on footprint (Numbers Bars) charts, where I use Volume at Price Multiplier Chart Settings.
I want to display the Bar Delta Value above a bar what works perfectly (using the Value on Low subgraph draw style) when the Vol. at Price Multiplier is set to 1.
But when I use a Vol at Price Multiplier value greater than 1 and change the Subgraph Draw Style to 'Value on Top' the displayed number overlaps the last footprint numbers and the study settings 'Offset in Ticks' does not have an effect on this. I can set this value to 10, 100 etc, but the value will still stay at the same place and overlap the Numbers bars.
When I try to display the Delta number below the bar (using the study default), the numbers do not overlap the bars, but the offset settings do not have any effect.
Can you please advise on how to setup the Delta Below Bar study properly to not overlap numbers bars values when using Vol at Price multiplier settings in chart settings?
Thank you.
[2020-08-18 20:03:56]
The issue you are having has nothing to do with the Volume at Price Multiplier. It is simply related to the Draw Style choices that you are selecting. Unless you leave the Draw Style at the default setting of Custom Value at Y, the Offset in Ticks Input is not going to have any effect.
If you really need to have the numbers displayed above the bars, then you should add the Study Subgraph Above/Below Bar As Text study and then you can set the top of the bar and set an offset in ticks from there. Refer to the information here:
Study Subgraph Above/Below Bar as Text
