Date/Time: Mon, 10 Feb 2025 01:50:35 +0000
line for target/stop and trade disabling
View Count: 742
[2020-08-18 17:22:46]
User845052 - Posts: 75
1) my issue is that the target and stop lines have a bit of invisible margin that, upon clicking, the lines are moved. this is not great for me because i'm finding myself accidentally moving them often when i am trying to draw something in the vicinity. i'm finding this quite restrictive as there is essentially an entire horizontal zone i cannot interact with on my chart. can I remove those lines completely, shorten them, or better yet, reduce the clickable margin?
2) nevermind, resolved
thanks
Date Time Of Last Edit: 2020-08-18 17:25:56
[2020-08-18 17:42:45]
just discovered a new problem
i have one chart that all of the sudden (this happened after restarting the app), will maximize, will minimize, BUT it will not restore! it completely disappears when i click restore and so i cannot move it around on a portion of the workspace, as i require. i feel like resetting the windows would fix this, but that is my last resort as i don't want to make reorganizing my entire screen the only solution for something this silly
[2020-08-18 17:59:11]
nope "reset windows" didn't work. the chart appears to be completely unusable now
[2020-08-19 19:27:05]
1. This depends upon the chart text size:
Graphics Settings: Fonts and Text Appearance
Try using one of the Window menu Tile commands:
Window, CB and CW Menus: Tile Horizontally (Window)
Additionally:
The chart has to be there somewhere. It should not have gotten out of the area of the main window, but try enabling on the option for Enable Workspace Scrolling, then exit Sierra Chart and start it again. Then see if you can scroll through the main window area and find the chart. Refer to the information here:
General Settings Window: Enable Workspace Scrolling (Global Settings >> General Settings >> GUI >> Scroll)
Date Time Of Last Edit: 2020-08-19 19:27:33
[2020-08-20 17:50:06]
Update:
1) i figured out how to right align the trade lines so they no longer interfere
2) "workspace scrolling" was able to locate the chart (almost thought i lost a second marked up chart)
Date Time Of Last Edit: 2020-08-20 17:50:23
