Date/Time: Mon, 21 Sep 2026 04:36:15 +0000
Compiler Issues
View Count: 1148
[2020-08-18 13:58:49]
rahul - Posts: 173
Hello, something is wrong with your compiler. My exact same code was compiling yesterday but today I am getting this issue: (I using the inbuilt SC Compiler)
I have tried with both version 2130 and 2150. Please fix compiler issues.
Anchor_18Aug2020_1.cpp: In function 'int ModifyOrder(SCStudyInterfaceRef, int, float)':
Anchor_18Aug2020_1.cpp:697:1: warning: control reaches end of non-void function [-Wreturn-type]
697 | }
Anchor_18Aug2020_1.cpp: In function 'int CancelOrder(SCStudyInterfaceRef, int)':
Anchor_18Aug2020_1.cpp:722:1: warning: control reaches end of non-void function [-Wreturn-type]
722 | }
User contributed studies are also not working, even though I have version 2149 and higher.
Date Time Of Last Edit: 2020-08-18 18:02:05
[2020-08-18 19:17:47]
Please look at these errors carefully and think before you make postings like this. You need to resolve the problem with your own code. There is no issue with the compiler at all. Do not post again further about this. You need to resolve the problem in your own code.
If you post again about this, we are deleting your posts.
And regarding user contributed studies, use the latest pre-release for support for those:
Date Time Of Last Edit: 2020-08-18 19:19:03
[2020-08-18 19:25:04]
rahul - Posts: 173
I have clearly mentioned there is no issue with my code as it was working yesterday and then stopped working this morning. You guys have made a change on your compiler side. I can compile the code in Visual C++ compiler, but its not compiling with the SC compiler.
Don't tell me about my mistake till actually looking into the issue! You guys are rude at times!
[2020-08-18 19:37:46]
ForgivingComputers.com - Posts: 1238
697 | }
722 | }
These are warnings. Are you sure it did not compile?
[2020-08-18 19:39:22]
rahul - Posts: 173
Exactly Bradh...these are warnings but its not compiling this morning on the SC compiler.
These guys at SC need to acknowledge it.
[2020-08-18 19:53:04]
rahul - Posts: 173
Anyway, I fixed it by rewriting that function with explicit returns.
[2020-08-19 19:33:58]
Really?:
Not at all. We are just simply telling the truth, and do not want false information posted.
You are telling us a compiler we did not develop is "broken" and to "fix it".
There has been a compiler update on the server, and often that means that there is stronger checking for invalid code.
There simply is no problem at all. The compiler works fine. The issue is with your code. And those are only warnings anyway.
Date Time Of Last Edit: 2020-08-19 19:34:20
[2020-08-19 19:45:30]
rahul - Posts: 173
I have been a customer for many years and have been writing code on the SC platform for over 2 years. I know the difference between a warning and an error, but the compiler refused to generate a DLL file.
Anyway I re-wrote my function to fix it. I didn't say you guys wrote the compiler, I merely asked to review it. I should have posted an image of the warning not compiling.
Again, there was no issue with my code as it was compiling 2 days ago and not yesterday until I re-wrote my function. There might have been a compiler update on the server, which could have caused it.
