Date/Time: Sun, 24 Nov 2024 20:41:40 +0000
Open P/L off by .01 Cent
View Count: 723
[2020-08-18 13:34:03] |
User597876 - Posts: 42 |
I have checked all the settings according to the instruction in the Sierra Chart documentation settings. This is happening as of today 8/1//20. It is doing it in the Current and Pre-release. I will not be available until after 12:00 PM CST today.
Date Time Of Last Edit: 2020-08-19 00:15:12
[2020-08-19 00:15:00] |
This is due to floating-point calculation error and is not anything we can help with further.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2020-08-19 00:15:05
[2020-08-19 00:59:49] |
I just this evening noticed that it is only doing this with the NQ. It isn't doing it with the YM or the RTY.
[2024-04-29 07:32:54] |
Profile Trader - Posts: 174 |
Is this something that has been resolved? Bit confused with the floating-point calculation error Can't believe that SC can not process the correct P/L based on entry. What am I missing here? it appears to be .0058 cents off per contract. Commissions are set to 0 in symbol Doug |
